159334:
sv: kodning af fjernbetjening til centrallås Freelander 1 (04-05-2018 12:20:48) (svar på
159333)
Poul List #8988, reg. mjyl (medlem) (
ip-adr: 128.76.132.110)
Hej Henning prøv dette.
The handset signals must be synchronized to the CCU. The synchronization
will be lost if the power supply to the vehicle or the handset is lost.
Synchronization can be reprogrammed by pressing the handset lock button five
times in quick succession with the ignition off. Alternatively, the ignition can be
switched to position II with the handset attached to the key ring, this will
automatically reprogram the synchronization. This is achieved by means of a
circular transponder antenna located around the outside diameter of the
ignition switch. For this to happen, the transmitter must be within 70 mm of the
ignition barrel.
