80472:
sv: stelnummer på P38 (08-04-2009 08:27:45) (svar på
80471)
ip-adr: 87.54.8.86)
Dette er sakset fra manualen:
VEHICLE IDENTIFICATION NUMBER (VIN)
An adhesive label containing the Vehicle Identification
Number and the recommended maximum vehicle
weights is located on the left hand side of the bonnet
locking platform.
The number is also stamped on the outside of the
chassis in the front RH wheel arch to the rear of the
anti-roll bar link.
NOTE: It may be necessary to remove
underseal in order to locate the number;
ensure underseal is restored on
completion.
Håber du kan bruge det. Der er ikke nogen illustration af selve stelnummerets placering, kun det på labelen og i ruden, men jeg går ud fra at du skal bruge det rigtige.
MVH Jakob E S
